Rear combination lamps
1. Remove the screws (A) that hold the lamp unit and remove the lamp unit.
2. Turn the socket and bulb assembly anticlockwise to remove it.
B- Stop and tail lamp (LED) - cannot be replaced
C- Rear turn-signal lamp
NOTE
• An LED, not a bulb, is used in the stop lamp/ tail lamp.
Contact a MITSUBISHI MOTORS Authorized Service Point when there is a need for repair or replacement.
3. Pull the bulb out of the socket.
4. To install the bulb, perform the removal steps in reverse.
NOTE
• When mounting the lamp unit, align the groove (D) on the lamp unit with the clip on the body and the pin (E) on the unit with the hole in the body.
Reversing lamps
1. Open the tailgate.
2. Insert a straight blade (or minus) screwdriver into the notch of the cover and pry gently to remove the cover.
NOTE
• Wrap a piece of cloth around the tip of the screwdriver in order to avoid scratching the cover.
3. Remove the socket and bulb assembly by turning it anticlockwise.
4. Remove the bulb by pulling it out.
5. To install the bulb, perform the removal steps in reverse.
NOTE
• When installing the lid, align the tab on the lid with the hole on the vehicle side.
Licence plate lamps
1. When removing the lamp unit (A), push it towards the left side of the vehicle body.
2. Remove the socket (B) and bulb assembly by turning it anticlockwise.
3. Remove the bulb by pulling it out.
NOTE
• When installing the lamp, insert tab (C) first then align and insert tab (D).
High-mounted stop lamp
NOTE
• An LED, not a bulb, is used in the high-mounted stop lamp.
Reversing lamps
Licence plate lamps
